16 years agohow to get DVI info from DVI-HSMC on DE2-115
Hello guys,
Now this basic problem really bother me, does any one know how to read DVI info from DVI-HSMC daughter board (DVI_RX) attached on DE2-115? Thanks a lot!!!!!3 Replies
This thread is quite old but in case you still have problem, here is what I did: I used on of the quartus project and export the pin planner. Then using the DE2-115 HSMC pin assignements, I am able to assign each pins coming/going to the DVI-HSMC. Then looking at the datasheet of the DVI_RX chip, and the pin descriptions, you can understand what each pin is doing. Also be careful that quartus stated that those I/O are 2.5V but the DVI-HSMC card I/O need 3.3V. Meach - Altera_Forum
Or Does anyone have an example of DE2-115 working with DVI_HSMC??
BTW, I checked the example of DVI-HSMC, they are built based on Cyclone III. Can I just modify a little from the example project and try to use it on my DE2-115?
Thanks!!!
