15 years agoHow to get 45Mhz clock out?
Hi dears: I am using ArriaGX devices, and the board's clock is 100Mhz which is input to the FPGA. And the system need a 45MHz clock, could you have any method to generate this clock through FPG...
15 years agoor add 9 modulo 20 (same ratio)
alternatively, if the application tolerates use 9 clocks with enable ON then 11 clocks with enable off. or alternate enable ON/OFF for 18 locks then OFF for two clocks. The modulo adder is much neater reusable way... http://www.alteraforum.com/forum/showthread.php?t=29224
