15 years agoHow to generate JIC file with two niosII CPU
There're two nios II SOPC in my design. After compilation of the FPGA design, the SOF file is generated. And for two nios II processor, I have edited the software and after compilation, two ELF image...
15 years agoyes, if you are booting from on-chip memory it should be pretty straight forward. you should be able to check the fitter report to see that the two on chip memories were initialized from the expected .hex files
