15 years agoHow to generate JIC file with two niosII CPU
There're two nios II SOPC in my design. After compilation of the FPGA design, the SOF file is generated. And for two nios II processor, I have edited the software and after compilation, two ELF image...
15 years agoAs per i know and u said that SOF is generated so from SOF you will be able to generate JIC
Just keep updated two elf files ( by buidling nios projects),compile your design in quartus and make jic from "convert programming file" in quartus gui.
