18 years agoHow to enable the internal differential termination resistor?
Hello I want to use the internal differential termination resistors in the stratix ii FPGA(EP2S60F1020C5) for LVDS receiving. The stratix ii handbook tells that these resistors can be set in ...
18 years agoI suggest that you consult Quartus II handbook, where you can find all necessary information. If it's not understandable, ask Altera support. Unfortunately the handbook has 2718 pages,
Basically a context menu with any windows software is a menu, that opens on right mouse click within the specific context, here in Pin Planner. customize colums is the entry name that allows to add columns to the Pin Planner. You should try. Also the operation assignment editor is straightforward, but Pin Planner is more comfortable. I apologize that I don't have the time to give a detailed tutorial just now. May be other forum members have. I still hope that also short hints can help. Best Regards Frank
