18 years agoHow to enable the internal differential termination resistor?
Hello I want to use the internal differential termination resistors in the stratix ii FPGA(EP2S60F1020C5) for LVDS receiving. The stratix ii handbook tells that these resistors can be set in ...
18 years agoWith V7.x Quartus software, the pin planner tool is the most comfortable way to enter and review pin location assignments, I/O standards, current strength and termination settings. You have to enable a column stratix ii termination in context menu Customize Colums and can activate differential termination for LVDS pins.
Alternatively, you can enter a new assignment name termination - stratix ii/..., value Differential, enabled yes for a pin or a pin group in Assignment Editor.
