How to effectively implement PCIe transfer?
- 2 years ago
Hi Allen,
Thank you for reaching out.
From the steps given, I believe that you are looking into 8.2. Write DMA Example instead of 8.1. The two questions you've raised are:
1. Do I only need to use one or a few descriptors to complete the transfer?
2. Is there a better way to implement data transfer?
To address your questions, the findings below are according to the user guide 21.1 as mentioned.
1. To use one or a few descriptors to complete the transfer, it is up to the transfer size that you wish to transfer. In PCIe system memory, the read and write descriptors are stored in separate descriptor tables. And each table can store up to 128 descriptors. Each descriptor is 8DW / 32 bytes. Based on the descriptor format, the maximum transfer size is (1 MB - 4 bytes). Hence, if you need to transfer large amounts of data, which is more than 4 bytes, you'll need to use a few descriptors (more than one) to complete the transfer. On the other hand, if the data is less than 4 bytes, then one descriptor will be enough to complete the transfer. However, take note that to avoid a possible overflow condition, allocate the memory needed for the number of descriptors supported by WR_TABLE_SIZE.
2. No. This is the way it works for DMA data transfer, as the descriptor ID will loop back to 0 after reaching WR_TABLE_SIZE.
If you want to process more pointers than the WR_TABLE_SIZE, there are two steps that you must follow:
1. Process the pointers up to WR_TABLE_SIZE by writing the same value as in WR_TABLE_SIZE.
2. Next, write the number of remaining descriptors to WR_DMA_LAST_PTR.
User Guide: https://www.intel.com/content/www/us/en/docs/programmable/683667/21-1/introduction.html
I hope these address your questions well.
VenTing_Intel
Hi Allen,
May I know if there are any updates from your end regarding this forum case?
I look forward to your response which will allow us to proceed to the next step.
VenTing_Intel
