15 years agoHow to edit the comment text in the pof file
I have found the format of the .pof programming file. I have a script to re calculate the CRC, however, even when making very simple single bit change to the date and re calculating the CRC, the Qua...
15 years agoHi, Tricky,
The name of the programming file is fixed, it is referenced in the BOM for the board, the firmware gets called up as all other componets are. I also wanted to establish a link between the source code and the programming file, hence the need to embed the version number in the comments packet of the pof file.
