15 years agoHow to edit the comment text in the pof file
I have found the format of the .pof programming file. I have a script to re calculate the CRC, however, even when making very simple single bit change to the date and re calculating the CRC, the Qua...
15 years agoUsually, you stick version numbers in the registers accessible from software to check this.
Could you not use the CRC as the version number?
