10 years agohow to count only adjacent(linked) 1's quantity in 7X7 matrix buffer using fpga?
hello. i'm studying image processing using fpga. i attached 7x7 matrix image. yellow is 1 and white is 0. normally i can count all 1's quantity in 7x7 matrix included un-linked 1, but i can'...
10 years agoYour camera line rate might be running at a 10KHz line rate, but the pixel rate is actually 10.24Mhz which is what the camera will be running a.
You shouldnt be passing whole lines around the system, that is innefficient - why not just process on a pixel bases? Processing on a line basis sounds like a software solution.. FPGA is NOT software.
