10 years agohow to count only adjacent(linked) 1's quantity in 7X7 matrix buffer using fpga?
hello. i'm studying image processing using fpga. i attached 7x7 matrix image. yellow is 1 and white is 0. normally i can count all 1's quantity in 7x7 matrix included un-linked 1, but i can'...
10 years agoI assume the code you have posted is incomplete, because it has syntax errors.
Your current code is somply the sum of all bits of an array in parrallel. I assume ultimately your input will be an image? this would be streaming only 1 pixel per clock cycle. To check adjacent 1s you're going to need an algorithm to found out whether one is adjacent to another. And to explain: In a processor - in a CPU Thresholding - taking an image and transforming the raw data by setting specific values to 0 (those that fail to meet some threshold criteria, eg. the luminance value is below a given value) 300 Hz refresh - the frame rate of the image - the pixel rate was 27Mhz.
