Radha
7 years agohow to convert .jic file from .pof file with the help of Quartus software?
Hi SooYL, Thank you for your response, while i am trying to convert to .jic file using quartus it is asking the input file format as .sof, but i do not have .sof file, I have .pof file for the EPCS1...
YuanLi_S_Intel
7 years agoHi Radha Pandi,
Can you try to recompile the design again? SOF should be able to generate if you have fully compiled your design in Quartus. It is not possible to convert using the tools if there is no option to attach POF.
YL
Radha
7 years agoHi SooYL,
Thank you for your response, I donot have any design code and .sof file.I have only .pof file of EPCS1 device and i should use that for the EPCQ4A device and i should program the EPCQ4A device. So can you help me in programming that new device with help of Quartus prime and USB Blaster programming cable.
Thank you,
Radha.P.
