18 years agoHow to control the I/O pins during power up or configration
Hi everyone, I'm working on a project which will use fpga as inteface for emif of TI DSP. I will use cyclone or cyclone II as this inteface chip. But some FPGA's I/O pins should remain Low durin...
18 years agoThat's a voltage divider you can calculate yourself. If you want to achieve TTL maximum VOL of 0.4V, not only 0.8V maximum VIL, then you need 1.3k or 1k rounded down. 1k pulldown guarantees maximum power-up level of 0.3V.
