18 years agoHow to control the I/O pins during power up or configration
Hi everyone, I'm working on a project which will use fpga as inteface for emif of TI DSP. I will use cyclone or cyclone II as this inteface chip. But some FPGA's I/O pins should remain Low durin...
18 years agoHello,
this can be achieved by a resistor. You have to consider minimum weak pullup resistance from datasheet and maximum VIL level for the input. I recently calculated 2.2k maximum pulldown resistance for a similar problem, 1k should work under all conditions without further calculations. Regards, Frank
