How to constrain the transceiver Rx data path?
- 3 years ago
How about sharing through email?
I'm dropping you an email, you may send your design through there.
The reason I am requesting your design is to check if the connection/usage of the IP is correct. From there, we can tell if it is a usage problem or timing constraint problem.
Nurina
Nurina
- RZhen113 years ago
Hi Nurina,
Thanks for the offer, I've resolved the issue by adding immediate register at the XCVR.output.fifo with rx_clk.
The actual design is under Export Control, so I can not share easily.
Please give me your email, I'd be happy to carry on discussion with code snippet and timing reports.
I'll mark "Resolved" here.
