RZhen11
3 years agoHow to constrain the transceiver Rx data path?
Dear support, I used to only constrain XCVR with the reference clock and expect the Quartus tool to derive all the generated constraints. Recently I found adding logics to the Rx data path is caus...
- 3 years ago
How about sharing through email?
I'm dropping you an email, you may send your design through there.
The reason I am requesting your design is to check if the connection/usage of the IP is correct. From there, we can tell if it is a usage problem or timing constraint problem.
Nurina
Nurina
3 years agoHi,
Can you also share the .qar file of your project?
To generate this, go to Project>Archive Project.
Nurina
RZhen11
3 years agoHi Nurina,
Thanks for your attention. I can't share the actual project due to IP consideration.
The part I am using is: 10AX048K4F35E3LG
