RZhen11's avatar
RZhen11
3 years ago
How to constrain the transceiver Rx data path?
Dear support, I used to only constrain XCVR with the reference clock and expect the Quartus tool to derive all the generated constraints. Recently I found adding logics to the Rx data path is caus...
  • Nurina's avatar
    3 years ago
    How about sharing through email?
    I'm dropping you an email, you may send your design through there.
    The reason I am requesting your design is to check if the connection/usage of the IP is correct. From there, we can tell if it is a usage problem or timing constraint problem.
    Nurina
