10 years agoHow to connect unused GXB_TX pins in an ARRIA GX device
I am trying to figure out how to terminate unused GXB_TXp and GXB_TXn pins in an Arria V GX device. Thanks, Dan
10 years ago --- Quote Start --- Dan - Have you read the Arria V pin connection guidelines? https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/dp/arria-v/pcg-01013.pdf This is a very important document for all families. It says to leave all unused GXB_TX pins floating. No need to terminate. Bob --- Quote End --- Thank you for the response. Yes, I did read that document. It says "Leave all unused GXB_TXp pins floating", which seems to inply to float just the "p" pins. Hence my confusion. Dan
