15 years agoHow to connect single REFCLK pin to rx_cruclk[3..0]?
QII says that my REFCLKp pin is not connected although clearly it is. I assume it does not like to have a single pin connected via a bus to four CRU inputs on my GXB block? Will I need to put a...
15 years agoOk, I figured this out. The input REFCLKp pin is connected to a bus named 'REFCLKp, REFCLKp, REFCLKp, REFCLKp'. This bus is then connected to the GXB block's rx_cruclk[3..0] input. See attached images.
