15 years agoHow to connect more than one FPGA-board
Hi, I am trying to educate myself a little on connecting three or more FPGA-boards. to make it short: If any of you guys sit on information/resources that you would care to share rega...
15 years agoHi,
they can comunicate to each other over the PCIe bus. Since the DE4 has a 4x PCIe 2.0 interface, you can get 4x 5 Gbit/s full duplex for each DE4, assuming the motherboard supports it. It's also possible to use the HSMC connector. You'll need to find or design a cable or PCB with suitable pinouts to interconnect two DE4s. Maybe SAMTEC has suitable assemblies. http://www.samtec.com/flex_circuitry/flex_standard_hs.aspx?s=cafc In terms of software and design, there's no support for managing more than one FGPA. Of course, Altera provides multiple comunication blocks (PCIe, SeriaLite, ALT_LVDS, etc) that you can and should use but beyond that, you're on your own.
