13 years agohow to connect analog input directly to FPGA Altera board?
hi; I want to implement Sigma Delta ADC on Altera DE1, i wrote the code and run on QuartusII; now i want to know is it possible to connect the analog input directly to the board? as in my co...
13 years ago --- Quote Start --- I want to implement Sigma Delta ADC on Altera DE1, i wrote the code and run on QuartusII; now i want to know is it possible to connect the analog input directly to the board? as in my code the input is introduced as signed [7:0] --- Quote End --- I don't understand the question. A SD ADC would preferably use a 1-bit modulator. Multibit modulators are a principle option in SD design, but they need digital correction and a multibit ADC and DAC to take advantage of the SD principle. See Chapter 8 of delta-sigma data converters, theory, design and simulation, by Schreier et al. I don't believe that you intend to design an analog frontend of similar complexity. I have seen FPGA evaluation boards (from Altera competitors, if I remember right) with a basic first order SD modulator comprised of a RC lowpass and a comparator. The comparator might be even replaced by a LVDS input stage.
