18 years agoHow to connect af microphone with 4 wires
Hi Where do you find the connections to the FPGA? I mean how do you know what pins to connect to the module you just progammed some code for ? I use the Nios II embedded evaluation kit cyc...
18 years agoHi
Thanks that helped a bit. I found the file. But I still can´t find any free connections. I have found this on the main board: Signal Name FPGA Pin Name Direction Type HSMC Pin HSMC_D0 H6 Bidirectional 2.5 V 41 HSMC_D1 D3 Bidirectional 2.5 V 42 HSMC_D2 M5 Bidirectional 2.5 V 43 HSMC_D3 L6 Bidirectional 2.5 V 44 But thay are alle connected to some chip on the daughter board? I just can´t find any free connections on the HSMC Expansion Connector. The best solution would be to find some free connections on the main board. BR Benjamin
