18 years agoHow to connect af microphone with 4 wires
Hi Where do you find the connections to the FPGA? I mean how do you know what pins to connect to the module you just progammed some code for ? I use the Nios II embedded evaluation kit cyc...
18 years agoHave a look at the excel file "CIII_SK_pinTable.xls" which you will find in the included documentation with your kit. You have to select one of the FPGA pins that are connecetd to the HSMC interface.
