18 years agoHow to connect af microphone with 4 wires
Hi Where do you find the connections to the FPGA? I mean how do you know what pins to connect to the module you just progammed some code for ? I use the Nios II embedded evaluation kit cyc...
18 years agoHi
Yes a microphone with digital audio output. Yes I just need to connect it to a digital I/O, but I would like to use the connections on the drawing but what is the pin connections in the FPGA that connects to these I/O? With the pin connections I mean in Quartus->Assignments->Pins BR Benjamin
