18 years agoHow to connect af microphone with 4 wires
Hi Where do you find the connections to the FPGA? I mean how do you know what pins to connect to the module you just progammed some code for ? I use the Nios II embedded evaluation kit cyc...
18 years agoHi
Sorry I should have told you that it is a digital microphone, so I just need 4 digital connections on the board. I have found the following connections on the daughter board: http://nygaard1899.dk/Daughterboard.bmp What 4 lines can I use? And what is the pin connection that I have to setup in quartus on the FPGA(CyloneIII EP3C25F324C6NES)? The drawing is from lcd_multimedia_daughtercard.pdf BR Benjamin
