8 years agoHow to configure ArriaV FPGA with GHRD RBF via QSPI
Hello, I'm currently stuck with an issue where the Arria V fail to program/configure from HPS QSPI. I'm using Arria V SOC DevKit and the files in Altera 15.1 GHRD. The preloader and u-boot...
8 years agoOK, so there was an improvement here. I changed the mSEL switch to 00110 and it worked. I can now access the FPGA registers which was not possible before. 00100 MSEL settings also work.
My next problem is that a slightly modified GHRD rbf (default GHRD rbf just added with LED blinker) is not working, even if I played with MSEL settings. Its .sof equivalent works, but what's keeping the rbf from working properly. If we can solve this, we can be more confident of doing our ArriiaV-based project.
