18 years agoHow to config ALTLVDS when deserialzation factor> 10?
Hello all, The max deserialzation factor of ALTLVDS is 10, how to cinfig ALTLVDS when deserialzation factor greater than 10 such as 16? The sending timing of source as http://photos.i.cn...
18 years agoThe said ADS6442 has up to 910 MHz data rate. I can be processed with dedicated SERDES hardware only. The half rate in two wire mode can be processed in LE with DDIO registers.
