18 years agoHow to config ALTLVDS when deserialzation factor> 10?
Hello all, The max deserialzation factor of ALTLVDS is 10, how to cinfig ALTLVDS when deserialzation factor greater than 10 such as 16? The sending timing of source as http://photos.i.cn...
18 years agoDepending on how fast the clock is you may not need ALTLVDS. You can create your own deserializer/serializer using DDIO primitive but still use the LVDS pins. You will need to manually tell Quartus in assignment editor these are LVDS pins.
ALTLVDS is limited to 10.
