15 years agoHow to compare outputs from a floating point IP such as altfp_div?
How can I compare outputs from a floating point IP since it gives output in IEEE format, comparative operators such as >, < will not work?
So if I have output out of two such modules how should I compare them? HDL being used is Verilog.1 Reply
have you taken a look at altfp_compare?
