13 years agohow to check PCIE read write operation in 64 bit processor
hi,
am using altera cyclone IV gx EP4CGX15BF14C7 device. for my PCIE project, am using 64 bit processor system, how do i check the pcie read write operation in 64 bit processor. in a 32 bit processor system, i had used the jungo driver "altpcie_demo_Qsys_32.exe", it was worked fine , when same Jungo driver is used in the 64 bit processor am not able to install. please sujject any software for PCIE read write operation in 64 bit processor.4 Replies
Search on Google for PCIScope and read and write memory software
hi how are you! I have the smilar project whice is Pcle between fpga and 32 Bit processor. it have found the problem that cpu read error once a time at thousand million for long time. so I expect share your experience.
hi how are you! I have the smilar project.
use COMMAND (w32 ADDR DATA) and (r32 ADDR)
