15 years agoHow to calculate parameters for reconfigure a pll
Hello, i'm implementing a reconfigurable PLL using an ALTPLL e ALTPLLRECONFIG megafunction. I initialize my PLL with an input freq of 50MHz and only c0 output clock with output freq of 100MHz...
13 years ago --- Quote Start --- Hello, i'm implementing a reconfigurable PLL using an ALTPLL e ALTPLLRECONFIG megafunction. I initialize my PLL with an input freq of 50MHz and only c0 output clock with output freq of 100MHz. I noticed in the Output clock tab this parameters: MODULUS FOR M COUNTER = 12 MODULUS FOR N COUNTER = 1 POST SCALE COUNTER = 6 HIGH PERIOD COUNT = 3 LOW PERIOD COUNT = 3 MODE = even now i changed the output freq from 100 to 125MHz and the new parameters are MODULUS FOR M COUNTER = 10 MODULUS FOR N COUNTER = 1 POST SCALE COUNTER = 4 HIGH PERIOD COUNT = 2 LOW PERIOD COUNT = 2 MODE = even Now the question: if i want to reconfigure my pll on-the-fly for generate an arbitrary frequency wich are the formulas to calculate the above parameters and pass them to the ALTPLLRECONFIG unit? thanks for the help --- Quote End --- Hi, Has anyone found any additional info for this? I am having the same problem and would like the formula to calculate M, N and Post Scale (C). The documentation I found provides the following: Fref = Fin/N Fvco = Fin(M/N) Fout = Fin(M/(N*C)) This info can be found here http://www.altera.com/support/devices/pll_clock/basics/pll-basics.html I still do not understand how M,N and C are determined. For example lets say my Fin = 25MHz and I want Fout = 37MHz. The megawizard determines M=111, N=5 and C=15. Does anyone know how these calculations were done? With a constant Fin I would like to reconfigure my PLL to an arbitrary frequency. Thank you
