13 years agohow to access TSE control port?
Hello all, I've checked all the possible solutions to get TSE working in gigabit mode, like pll rx and all the suggestion by an440 but no way. There's another suggestion by accessing a "contro...
13 years agoThis register is a PHY register, which is accessible through MDIO. To use the TSE's MDIO master, have a look at the datasheet (http://www.altera.com/literature/ug/ug_ethernet.pdf) at pages 6-2 and 6-5. You will need to write first the PHY's MDIO address in mdio_addr0 or mdio_addr1, and then you can directly read/write the PHY's MDIO registers using the MDIO space 0 or 1.
In your example, if you write the PHY's MDIO address in the TSE register mdio_addr1 (0x10) then you can access the extended PHY specific control register through the TSE register 0xB4 (which is 0xA0 "MDIO Space 1" + 20)
