13 years agohow the data is transfered using PCIE LINK
I am using the altera S2GX for a project uses PCIE to transfer data. Now we have the hardware working with the PC, since altera didn't provide the source code for the pc app. I am not sure...
13 years ago --- Quote Start --- You're probably not getting any replies because you're jumping into PCIe without actually spending any time to understand what PCI and PCIe is. Take a look at the document I posted on this thread: http://www.alteraforum.com/forum/showthread.php?t=35678 Now, to answer a few basic questions for you. 1. A PCIe BAR is a "base address register", its basically a window into the address map of your board. Lets say your board had 4kB of registers that the host needed to access, then the BAR size would be 4kB. The physical address of the BAR in the address map of the RC (the host PC) is determined by the BIOS at boot time. The guy writing the device driver on the host needs to know that address, but that is easy, as the device driver just asks the operating system. 2. A PCIe end-point does not usually use big BARs. Why? Well, a host like a PC does not usually have a DMA controller, and performing reads and writes as 32-bit or 64-bit operations is really efficient ('cause they get packed into serial packets with headers etc). A PCIe end-point usually has a DMA controller, and that DMA controller is what your host device driver programs to move data around, i.e., the host can use a small number of inefficient writes to setup the DMA controller, and then say "go", and the DMA controller will move large volumes of data efficiently. Writing Linux device drivers for PCIe devices is very simple. In fact, you don't even need a device driver for simple accesses. The thread above has an example program that allows you to read or write from the PCIe BARs. Cheers, Dave --- Quote End --- Thanks for you reply first. I had spent some time on simulating the PCIE packet at fpga side, so I thought I had some understanding of the PCIE TLP packet, at least, without going to deep into the core of PCIE. I know how the interface signals. anyway... I am playing with the PCIE testbench simulation today, Now I understood that BAR is one to one mapped between the RC and EP. I think in my case BAR0/1 is used for simple memory read/write and BAR2 is used for DMA. looks like the BAR is also mapped on the system memory address with same size, I understand the basics of DMA which frees the CPU from handling all the data moving work. (isn't still require a method to tell the EP which address to start?) at the EP, I have a 20Gbytes nand flashes, should I make the BAR bigger? or there is other way around? lol I dont think I can make BAR 20G, right?
