16 years agoHow read data file in a testbench
Hi all:
Im trying to do my testbench, i want read the inputs from a .txt file and write the outputs to a .txt file library IEEE; use ieee.std_logic_1164.all; use ieee.std_logic_textio.all; entity testUnidadALULog is end; architecture test of testUnidadALULog is COMPONENT UnidadALULog is port( DatoA : in std_logic_vector (31 downto 0); DatoB : in std_logic_vector (31 downto 0); Operacion : in std_logic; --- 1 para Mulltiplicacion 0 para Division AUXDATO_A, AUXDATO_B : out std_logic_vector (35 downto 0); AUXSUMA : out std_logic_vector (36 downto 0); AUXRESTA : out std_logic_vector (36 downto 0); AUXselector: out std_logic_vector (36 downto 0); Resultado_Entero : out std_logic_vector (63 downto 0) ); end component; signal PruDatoA, PruDatoB : std_logic_vector (31 downto 0); signal PruOperacion : std_logic; signal PruAUXDATO_A, PruAUXDATO_B: std_logic_vector (35 downto 0); signal PruAUXSUMA, PruAUXRESTA: std_logic_vector (36 downto 0); signal PruAUXselector: std_logic_vector (36 downto 0); signal PruResultado_Entero: std_logic_vector (63 downto 0); begin Pruebas : UnidadALULog port map ( DatoA => PruDatoA, DatoB => PruDatoB, Operacion => PruOperacion, AUXDATO_A => PruAUXDATO_A, AUXDATO_B => PruAUXDATO_B, AUXSUMA => PruAUXSUMA, AUXRESTA => PruAUXRESTA, AUXselector => PruAUXselector, Resultado_Entero => PruResultado_Entero ); verificar : process file datosin: TEXT open read_mode is "pruebasin.txt"; file datosout: TEXT open write_mode is "pruebasout.txt"; variable linea: line; variable vDatoA, vDatoB :std_logic_vector(31 DOWNTO 0); variable vOperacion: std_logic; begin while not endfile(datosin) loop readline(datosin,linea); read(linea,vDatoA); read(linea,vDatoB); read(linea,vOperacion); PruDatoA <= vDatoA; PruDatoB <= vDatoB; PruOperacio <= vOperacion; wait for 200 ns; write(linea,PruAUXDATO_A); write(linea, string'(" ")); write(linea,PruAUXDATO_A); write(linea, string'(" ")); write(linea,PruAUXSUMA); write(linea, string'(" ")); write(linea,PruAUXRESTA); write(linea, string'(" ")); write(linea,PruAUXselector); write(linea, string'(" ")); write(linea,PruResultado_Entero); writeline(datosout,linea); wait for 350 ns; end loop; wait; end process verificar; end test; but when I comile testUnidadALULog.vhd in ModelSim program I have 2 Errors # Unknown identifier text. # File declaration must have a subtype indication that is a file type do you know how what I have to do??? Thanks!!!!!!!!!!!!!!!11 Reply
you need to include the library std.textio.all aswell. std_logic_textio is just to get the std_logic/std_logic_vector write functions. functions for string, integer, bit (ie all the base types) are in the std.textio package. It also contains the text file type.
