15 years agoHow generate .SOF
Hi, I construct new project, and i created new SOPC. After i generate the design. Second i make the assignement pins for the IP. When i passed to download the program after the compilation...
15 years ago --- Quote Start --- If you look in the assembler report and click on "generated files" you'll see all the files created by the assembler and their location. To check/change the path the files are generated in, go to the Assignments menu, Settings, Compilation Process Settings, and in the window, check box "Save project output files in specified directory" --- Quote End --- Yes you have a reason, when i try to check the assembler report, i find a warning "Can't generate a programming file because you use evaluation version of Quartus II".
