15 years agoHow generate .SOF
Hi, I construct new project, and i created new SOPC. After i generate the design. Second i make the assignement pins for the IP. When i passed to download the program after the compilation...
15 years agoIf you look in the assembler report and click on "generated files" you'll see all the files created by the assembler and their location.
To check/change the path the files are generated in, go to the Assignments menu, Settings, Compilation Process Settings, and in the window, check box "Save project output files in specified directory"
