15 years agoHow generate .SOF
Hi, I construct new project, and i created new SOPC. After i generate the design. Second i make the assignement pins for the IP. When i passed to download the program after the compilation...
15 years ago --- Quote Start --- If you are targeting an "Advanced" or "Initial Device" for the version of quartus, you can not generate the SOF file. For version 11.0 this is usually the Stratix V at this point. If you really need the device support, (IE you have devices in house). Either upgrade to the latest version of quartus, or contact your rep to see if you can get pre-release patch to turn on SOF generation for the family you are targeting.. --- Quote End --- Think you a lot for your reply, I use Quartus 9.1 because this version it given by the board that's a bought directly from the site of Altera. I don't know really how i will travel with this board because i met many problem, for example that's i write in this thread http://www.alteraforum.com/forum/showthread.php?p=126717&posted=1#post126717, and when i start to release my SOPC from the begening i find this problem, really it is shocking for me. Ok, my friend can you help me how can i do to abtained the pre-release patch to turn on SOF generation? Thanks :)
