10 years agoHow does one overcome limitation of altera clock control block inputs?
The altera clock control block allows one to switch between 2 PLL clocks. These clock control hard IP blocks are fixed to specific PLLs. Is it bad idea to use normal logic multiplexer only beca...
10 years agoIt isn't recommended, but mux in logic can work fine.
It's discussed a bit on page 737 (page 11-7) of https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/qts/qts_qii5v1.pdf I've used the module in the cookbook (page 16-4) https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/manual/stx_cookbook.pdf It depends on your application, but I've also used reprogrammable cascaded PLL
