13 years agoHow do I cascade two PLLs?
Hi - In order to get a particular clock ratio, I need to cascade two plls. PLL0 has a pin input, and a single output. PLL1's input is the output of the first PLL, and has multiple outputs which go ...
13 years ago --- Quote Start --- Once I routed the first pll output to clock output pin, which was connected to clock input pin of second pll. This worked fine, although I didn't measure the jitter performance of the second pll. -Topi --- Quote End --- what did your .sdc file look like? did you specify anything other than the input to the first PLL?
