18 years agoHow Could I use DDR in CyClone III Starter kit successfully?
Hello, I try to use the DDR in Cyclone III starter kit ,But I try it a lot of times ,It is not success ,even I do not know why I cannot to use the DDR IP.When I generate the project it hints err...
18 years agoPlease check you have valid license to use DDR IP Megacore. If you have valid license then you should be able to generate your required system through SOPC Builder, you can use DDR SDRAM High Performance Controller with PSC A2S56D40CTP-G5 as Memory Preset for Cyclone III Starter Kit
