13 years agoHow can I use the serial BER fuction in StratixV device?
I want to Use the EyeQ function of StratixV inline , and I need the EyeQ non-intrusive data eye monitoring. But,there is no interface or register(avalon-MM) related to it.1 Reply
Where did you find the documentation on non-intrusive EyeQ monitoring in Stratix-V devices ?
I'm looking at the latest Transceiver PHY IP Core User Guide. It only has Horizontal and Vertical phase EyeQ registers. From what I understand, those are setting up data sampling clock. You need to implement error checking of the data. Also, the received data has to be known, for example specific PRBS pattern. Thanks, Evgeni
