13 years ago
How can I use clock on cyclone II ?
Guys,
Do you know how to use a clock in cyclone 2 ?
Connect the PLL output into CLK0 ? and configure it on quartus ?
I tried to read on :
7. PLLs in Cyclone II Devices
But don't understand clearly on how to use it....
What's the simplest way to use get a clock on cyclone 2 ( EP2C8Q208)? in uC it's very simple for a clock source, a network of 2 capasitors and crystal....
Any links or eperiences will be appreciated.
    --- Quote Start ---
    Lift you up by your own bootstraps? You're still missing a clock source for the PLL.
    As there's no inbuilt oscillator circuit, you would typically use a four-pin crystal oscillator device. Looking at a basic development kit schematic should give you an idea how.
    --- Quote End ---
    can I use this one ?
    http://www.ebay.com/itm/4-pcs-50-000mhz-dip-4-50-000m-50m-50mhz-crystal-oscillators-3-3v-/370804552950?pt=lh_defaultdomain_0&hash=item5655ac74f6
    --- Quote Start ---
    --- Quote End ---
    So I need external clock source. Do u know the link of the schematic? Tx
    --- Quote Start ---
    --- Quote End ---
    Hello bianchi.
    you don't have an oscillator in a Cyclone device so 2 capacitors and a crystal isn't enough. Electronics components stores like mouser or digikey have integrated oscillators. With Cyclone II i used an SMD 50MHz 3,3V oscillator of ABRACON.
    Configure the PLL it's easy. You have a Wizard to do it. Then you instantiate a component pll in your vhdl file. A detail: I use global reset active with '0' and the pll has reset active with '1'. Don't forget the inverter in your design or you'll see it hanged.
