8 years agoHot to create an Internal Memory Initialization (.hex) File in NIOS ?
I'm a beginner in Nios II software development. I am using Altera Quartus 14.0 web edition, the Qsys and the Nios II SBT for Eclipse, and device family is Cyclone V. I need to generate the internal Memory Initialization (.hex) File in NIOS but i don`t know how to generate Memory Initialization folder inside Software Directory [NIOS II] ? whereas Memory Initialization folder contains .HEX file, qip file and spd file. Steps to create memory initialization files in the Nios II Software Developer's Handbook. in which workspace i need to follow the below steps : 1. Right-click the application project. [Which will indicate application project ?] 2. Point to Make targets and click Build to open the Make Targets dialog box. 3. Select mem_init_generate. 4. Click Build. 5. Add the .qip (meminit.qip) file to the Quartus II project. Can anyone explain me the flow that where should i need to follow the above steps?1 Reply
It is (Built-in tool) eclipse project, right click on the project folder(Not on the project BSP folder). Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
