18 years agohot socketing question
Hi experts, I would like to know if it is possible to drive Cyclone 3 I/O pins when the device is not powered (hot socketing) ? If yes, how much leakage current the I/O pins will draw ? I did...
18 years ago --- Quote Start --- It should be noted that there is a big difference between NON POWERED and HOT SOCKETING. --- Quote End --- Nevertheless, the device handbook is discussing power sequencing under the hot socketing chapter. That's plausible to my opinion, cause hot socketing is relying on the same I/O cell features as power sequencing. Thus I'm pretty sure, that the quoted leakage specification (I omitted the dynamic current specification) also applies to the discussed case. The hot-socketing case doesn't make any assumption regarding order and timing of the sequential connection of signals, in so far it's the worst case that must be expected to include all power sequencing cases. --- Quote Start --- I recall that there is a note somewhere mentioning that if the Vccio of the bank the pins are located in is NOT powered, then the leakage current may be considerably higher. --- Quote End --- Yes, obviously is 300 uA higher than 10 uA leakage specification in normal operation.
