15 years agohostpc like send data to nios II via jtag (nios2-terminal.exe, jtag_atlantis.dll)
hi! my system: cyclone 3 starter kit quartus 2 - 9.1 ( licence + nios licence) nios 2 system working goal: i want to setup a matlab gui to switch some pio outputs of the nios. with it...
15 years agoHi wombat!
my last message wasn´t direkted to you. - it was only frustrating to find a hint to the solution and the needed information is not public. it also should be just a funny comment :). thank you for your excellent manual of getting the connection work. my only projekt is, that i cannot add the paths to the librarypath.txt. i was told that i do not have the rights on my computer to change librarypath.txt. when i rename the original librarypath.txt to librarypath_old.txt and put in a elsewhere written librarypath.txt. i get the known problem: "java.lang.NullPointerException". so i tryed loadlibrary('includepath','c:/altera/11.0/quartus/sopc_builder/model/lib/'); loadlibrary('includepath','c:/altera/11.0/quartus/bin/'); but now i get: ---------------------- ??? Error using ==> loadlibrary at 368 Failed to preprocess the input file. Output from preprocessor is:lcc preprocessor fatal: Can't open input file c:/altera/11.0/quartus/sopc_builder/model/lib/ ----------------------- i think matlab wants a *.h, *.dll, ... file. in my opinion the needed file should be in one *.jar file i had no success of just loading a directory. perhaps you know a solution (hope this is the last problem of loading the matlabapi ... ;) )
