18 years agohigh speed pulse generation
I have an application in which I will be using a NIOS with some low speed logic ~30Mhz or so, but I also need to have a small part of my logic for generating high speed, high resolution pulse trains ...
18 years agoIt sounds most like the timing generator in ATE. I had ever designed the digital channel board in a ATE. FPGA is not a good candidate.
