18 years agohigh speed pulse generation
I have an application in which I will be using a NIOS with some low speed logic ~30Mhz or so, but I also need to have a small part of my logic for generating high speed, high resolution pulse trains ...
18 years agoThis is one way I was thinking it could work, but I didn't know about the x10 mode. I would need a larger buffer than 10bits, but at least that only needs to work at 100Mhz. I have a different solution now using delay lines but I will keep this in mind. What do you think is the cheapest/lowest grade family that would be capable of this?
