18 years agohigh speed pulse generation
I have an application in which I will be using a NIOS with some low speed logic ~30Mhz or so, but I also need to have a small part of my logic for generating high speed, high resolution pulse trains ...
18 years agoMy experience with the altera PLLs is that they are intended to be tuned once for your design and left at that setting. If I could also perform dynamic adjustments that might be ideal , but I have not seen anything that would suggest it is possible. If you know of any app note or example, please let me know. I believe some of the xilinx parts incorporate DLLs which may be even more applicable provided you can get at those registers after configuration.
