18 years agohigh speed pulse generation
I have an application in which I will be using a NIOS with some low speed logic ~30Mhz or so, but I also need to have a small part of my logic for generating high speed, high resolution pulse trains ...
18 years agoI do not think you will be able to accomplish what you want using the High Speed Serial transceivers in the GX families.
In your restatement of desired situation, what you are really looking for is fine grained starting edge capability of the pule trains. (from one to the other) You might be able to do this with PLL dynamic phase controls. I would look into that potential.
