10 years agohexout versus jic delta in arria V epcs128
We are writing our flash device with the contents of the .hexout file (bit reversed across 8bit words). this is working fine on the arria 2 devices but not so well on the arria 5. We are bit banging ...
10 years agoI had a similar problem with generating hex files for Cyclone V remote update. My update logic which was used with Cyclone III before depends on checking the image header checksum which simply didn't work with Cyclone V hexout due to format changes. My solution was to convert the jic file to hex. The source is appended "as is". It extracts the hex file from a production image jic ant that uses a non-zero start address by default.
